The car is acting crazy. Can you guys help?
Here's the issue
I put on some long tubes and obviously didn't get the O2 wires far enough out of the way. They melted together and blew a fuse. I got the car home, fixed the O2 wires, but now it wants to idle at 4000, even with the TB completely shut. I unplugged the IAC and that didnt' fix it. I unplugged the IAC and the TPS and everything seemed to be fine for a day or 2, but now it's doing it again.
Pulled the codes, and the only one that seemed fishy is MAF low volts. I swapped the MAF with a known working one (as with the TPS and IAC, all in different combonations), still no luck.
Any ideas?
Also, FYI, this is engine has been swapped into a 93 RX7. Some of the power wires have been combined. For example, GM used 2 15a circuits, 1 for each set of coil packs. I used 1 30a service with both sets.
Any ideas?
My '99 Trans Am is doing the exact same thing after I burned one of the O2 sensor wires on the header. I got a P0121 code so replaced the TPS, it worked for a week. After that I retorqued the wire harness connections at the PCM, that worked for nearly a month, then it all of a sudden went back to idling at 4,000+ rpm. Recently I changed the maf sensor and still no change. Did you fix your problem N21923, or does anyone know what's going on?
