any advice on lean codes??
Old Mar 5, 2008 | 09:29 AM
MarcouxTA's Avatar
Default any advice on lean codes??
i have a 98 TA Ls1 and a couple add ons 29lb inj, K&N, cat back exh, 160" stat, hypertech controller. When i have my settings calibrated in the cpu the some bich throws all 4 o2 codes lean?? any ideas??
Old Mar 5, 2008 | 09:57 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
What codes are they specifically?
Have you tried putting the stock tune back in the car to see if the codes still appear?
Old Mar 5, 2008 | 12:30 PM
jimmyblue's Avatar
Moderator
First off check your arithmetic on the injectors, the
rating pressure vs the LS1 rail pressure and so on.
Then squeeze all the oil out of that sock and clean
the MAF real good.
Old Mar 5, 2008 | 07:07 PM
MarcouxTA's Avatar
cool im doin a real good summerizin in like two weeks, you know all the fluids, etc... ya i clean all the intake tubes every year and the air box and oil sock. im considering a aftermarket maff. T.B. and maybe a f.a.s.t. intake. If i change the tuning to stock the ses light doesnt go on. Its only when i put the pedal to the fan!!
Old Mar 5, 2008 | 08:07 PM
shoemike's Avatar
don`t ignore lean codes.
get a WBO2 and see what your AFR is.
you may need the tune adjusted or
you may need to clean your MAF, replace O2`s....ect.
Old Mar 6, 2008 | 09:59 AM
bigfatls6's Avatar
What sock are you guys talking about squezeing the oil out of? is there one on the 99s also?
Old Mar 6, 2008 | 04:01 PM
MarcouxTA's Avatar
you probably have one its in the air box for the pcv sys, unless some dumb *** yanked it!! I have the GM tech 2 and have checked all the inverter and even put a true occillicope on the injectors while driving!! should i clean it with electronics cleaner?? their real sensitive!! i really want to adress this before i do it up in the spring!! thanks for all the suggestions, im trying them this weekend!!
Old Mar 6, 2008 | 04:30 PM
2xLS1's Avatar
He was refering to the K&N filter the guy said he was using.
Old Mar 6, 2008 | 05:33 PM
BigPapi61's Avatar
CRC makes a cleaner just for your MAF. I got a can of the contact cleaner they sell at Home Depot. Sprayed the MAF, codes went away. I made sure to wring out that sock real good next time I cleaned it
