Anyone know the exact # of re-writes the PCM can take?
I found a limit . . . unfortunately :o
Anyone have any info on this?
Anyone fry their PCM's after a LOT of program uploads from Edit??
Re: Anyone know the exact # of re-writes the PCM can take?
This question came up not long ago on the LS1edit mailing list. I believe the answer was around 1200 programming cycles. But there was a bad batch of PCM's that are shot after much less. I've probably done mine close to 100 times so far.
The chip in the PCM allows for around 3,000 flashes.
I would suspect LS1edit is the cause and somehow swaps 2 offset address bytes (LSB/MSB) and writes where it should not.
I have seen a PCM after a valid upload from that point on never function as it did before the flash was done and even when the orginal flash file was uploaded back in the PCM still was not back to normal.
IT depends.
If you have a service replacement PCM, you may get 5 flashes out of it. This is an intentional limit put in by GM. I have my sources...
Otherwise, a factory installed PCM is, as far as you'll care, unlimited (as discussed above).
Ryan K.
Ryan K.
I have probubly 100+ on mine and no problems.....it does not make since that the PCM would have a "limit" of how many times it can be flashed.....
IT depends.
Ryan K.
Ryan K.
joel(Bink )
IT depends.
Ryan K.
Ryan K.
Thanks for the input gentlemen
