Annoying lean spike help please:
In 1600 and 2000 rpm colums only, at less than 15% throttle only I get an annoying lean spike every 5.5 seconds. Any gear, any road speed. Every 5.5 seconds. I have OLSD tune so there is no MAF to worry about, nor stock O2s failing. It feels like the car hits a rev-limiter for one instant, spikes lean and then goes a bit rich and then settles back in line. For 5.5 seconds. Sure makes cruising around corners interesting with the Locker
What the Hell is that? I can find nothing in the fuel control that happens at less than 15% throttle or every 5.5 seconds.
The only thing that happens is the spark advance drops to almost 0 every time it happened.
Maybe the car gets enough of a whiff of "deceleration"
to kick that in. Try disabling DFCO entirely and see if it
quits the behavior. If so then the next question is,
what accounts for triggering it rhythmically?
. We will see if that fixes the cruise lean spike/stumble. I think it should.
. You should be able to lower it back again if you play with your MAP, RPM, and VSS settings. I have mine to come in [way] under about 5% and it never comes on when I don't want it to.
