Anyone use innovative logworks for VE tuning?
Anyone here use innovative logworks to automatically calculate value for VE tables in hp tuners? How is it working for you if so?
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I would doubt it, because there is the way to get
AFR_Error histogram straight from the data stream
within HPTuners software.
LogWorks, you'd have to get the MAP & RPM fused
with the AFR data somehow. Meaning the AuxBox
or RPM cable + MAP + 5V supply.
Ya i have an aux box, it looks like you can just paste your current VE table into logworks. Then go drive around to fill in your table with the AFR/RPM data. It then will calculate all your values, and you can just paste the data back into HP tuners.
Looks pretty slick.
Looks pretty slick.
