Commanded Afr Does Not = Actual Afr @wot
#61
No problem! I just finished my WOT tune this weekend at the track. I just set my cell hits back down to 0 and just took the numbers from the higher frequencies and didn't mess with the lower numbers because i knew they were off on the few hits they had. It took about 3 passes before it was all squared away.
#63
#64
seems like it.. now im gonna expirment with using the unused portion of my maf frequencies to add fuel for my dry shot..
in theory if i can hit these with my dry kit all i will have to do is change the g\sec value in the maf table and it should add more fuel...(in theory)
#68
You Said Make Sure To Raise Them To Add Fuel... Im Thinking "i What Else Could I Do".. I Did'nt Know If There Was Something Else That Can Be Tuned Throught The Maf... (ie: Mabye I Was Missing Sometihng)
#70
Im Gonna Try 1st And See What The Maf Does On Its Own As Mabye Just Hitting Those Last Few Frequencies That I Cant Hit N\a Will Add Enough Fuel ; If Not Then I Will Jsut Start Jacking Them Up Until Hitting Those Frequencies Give Me The Desired Afr.. My Only Concern With This Is That In The Winter I May Actually Hit Some Of These Frequencies.. Luckly I Live In Fl And Its Only Cold 2 Days Out Of The Year So Its Really Not A Big Concern
