Shift points for A-4
2001 z28 with
Flp long tubes
Slp air lid
373 gears
3600 vig
Slp air lid
Loud mouth cat back
Tr 224 cam
The car will not shift in to 3rd at WOT how can I fix this I have a HPP3 What shift point should i set them at
I know i need to get ls1 edit
Thanks
Rob
RPM below your rev limiter. You should have your
gearing accounted for, first. Then, you need to
lower the MPH points to something that makes
sense (like look at the speedo when you're tagging
the limiter, and set the shiftpoint to about 3MPH
less).
(1-2) a 1 mph increase or decrease is 150 rpm
(2-3) a 1 mph increase or decrease is 79 rpm
(3-4) a 1 mph increase or decrease is 50 rpm
Dyno your car and read the torq curve. To set the best shift points do the math to have it at 100 rpm below max. Raise your RPM limiter to be 100rpm above shift point. TEST with run at WOT.
Adjust accordingly if necessary.
Hope this helps a little
My set up 3-3-6 Rev limiter 6300 rpm 50% firmness. (As per my mods) STREET.
TRACK 4-5-9 Rev limiter 6500 100% firmness. (Harder launch) with ET"s
