help,,,,,,,proplem after new plugs
Old Aug 7, 2003 | 01:07 AM
silverTA's Avatar
Default help,,,,,,,proplem after new plugs
i just but my new plugs(ngkTR6 ga at 37) in the car wouldn't idle wright and cut off on drive i dunnnnnnnnnnooo whats wrong,,,
mods(LT,ORY/NX kit)
i used one of my friend scanner and this code P0300 show also it was saying i got miss fire ,,
what i need to do
Old Aug 7, 2003 | 02:09 AM
silverTA's Avatar
Default Re: help,,,,,,,proplem after new plugs
TTT
Old Aug 7, 2003 | 03:24 AM
Jabroni's Avatar
I'll assume you've verified that the wires are all on and snapped securely on the plugs. Did you disconnect any of the plug or coil wires from the harnesses? Any wires arcing?
Old Aug 7, 2003 | 04:52 AM
silverTA's Avatar
I TOOK THE COILS OFF(PASS SIDE TO GET TO THE LAST PLUG)BUT I PUT EVERYTHINK BACK ON,,ALSO I DISCONNECT THE HARNESSES(WHITE PLUG GO TO THE COILS)
Old Aug 7, 2003 | 08:46 AM
jyeager's Avatar
This is usually caused by a loose connection, loose wire, or in the case that there are multiple misfires, perhaps some wires are crossed.
Did you damage any of the boots while pulling the wires?
Old Aug 7, 2003 | 10:45 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Yep, go back and check all your plug wire connections. Make sure you feel that "pop" as they go on. P0300 is random misfire code.
Tony
Old Aug 7, 2003 | 12:51 PM
silverTA's Avatar
i'll try this 2night ,,but is there anyway could be broken spark plug
Old Aug 7, 2003 | 02:00 PM
Colonel's Avatar
Yes, it could also be a cracked plug (the ceramic part.)
Old Aug 7, 2003 | 03:34 PM
30thWS6's Avatar
Are you sure you're running the proper heat range?
Old Aug 7, 2003 | 03:42 PM
silverTA's Avatar
am running 37 on JGKTR 6
Old Aug 7, 2003 | 06:51 PM
30thWS6's Avatar
What mods do you have that require you to run a colder heat range?
Old Aug 8, 2003 | 12:19 AM
silverTA's Avatar
am running 150 shot wet kit
i got my car fix i took all the plugs off and in #8 cy the plug was gaped at 28 not 37 ,,and #4 cy there was a cut in the wire ,,i put new plugs and new wires
thanx guys for the help,,,i dunno what to do with out this site
