Warm/hot start issues, IACs, and "cruise control" effect....
Old 08-20-2003, 04:05 PM
  #41
gillbot's Avatar
Default Re: Warm/hot start issues, IACs, and
114 and a 110/111 lsa cam are a bit different
Wow I must be lucky because all I did was turn my idle screw a bit and it idles like a champ.
224/224 114
Old 08-20-2003, 06:36 PM
  #42
Bink's Avatar
IMO, the only missing element now to getting a perfect startup idle is being able to tune the timing temperature table. If you log with EFILive, you will see that the PCM only allows about 15 to 20 degees of timing on startup. When the engine hits about 100*F, suddenly the timing jumps up 10 degrees and the idle instantly improves! But we need that next version of LS1edit to gain access to this table . . . come on, Ken Kelly!
Just got the new 1.29 version and it indeed has the temp vs. spark. I'll try that out and see how it works. There are quite a few updates in ver. 1.29. Theres also a Secondary VE table that has been added.
Do you mean the Crank VE table or is there a third table???
Old 08-20-2003, 07:12 PM
  #43
Ed Blown Vert's Avatar
224/224 114
Hmm I saw 221/221 .558/.558 114 in the first post.
Old 08-21-2003, 05:47 AM
  #44
gillbot's Avatar
Mines a 230/224 110-111 lsa
Quick Reply: Warm/hot start issues, IACs, and "cruise control" effect....
