car wont idle
You say your voltage is fine. Where did you test it? I am pretty sure p1637 refers to circuit continuity, not voltage. Also, what year is your car? The later PCM's used this error code differently. Check all ground wires on the block and chassis. Also, check the integrity of the PCM's ground.
yeah its weird, its a roadrunner pcm 99on02os, i ran a wire straight from the PCM to the alternator. Ive seen anywhere from 120-310 on IAC at idle. After i got done wiring it straight to the pcm the voltage is around 10-11 from having the door open so now it wont even turn over.
