HElp, car will barely run?,CODE P0160.
Car ran fine, then 3 weeks later I pulled it out and after a few minutes, it would barely rev too 2500 rpms without missing really bad. Just took it out again and it finally through a code P0160 reads: o2 Sensor CKT NO activity (bank 2 Sensor 2). Would this cause the car too run terrible?
Its starts and idles fine and even revs fine, but under load it will spit and sputter. cars has shorty headers, gutted cats and STS turbo. Thanks for the help. also, is it the driver rear 02 ???
Its starts and idles fine and even revs fine, but under load it will spit and sputter. cars has shorty headers, gutted cats and STS turbo. Thanks for the help. also, is it the driver rear 02 ??? Last edited by stepuptata; Jun 20, 2008 at 05:14 AM.
Bank 2 is pass side. If you gutted the cats, you need to do the rear O2 deletewith either the tune or simulators. It is probably in Cat protection mode which will command anywhere from 10 ~ 11 to 1 A/F ratio.
no more po131 code, now I have a :
PO131 code, ( o2 sensor circiut, Low Volts, Bank 1 Sensor 1.
I decided too drive the car through the missing and it actually got better the more I drove it. Once I stop for 5-10 minutes, It will miss heavy again and then start getting better. Then the PO 131 code pop up. Is this driver front O2 sensoe, Thanks.
