Computer Or Leak?
Old Jun 21, 2008 | 01:02 AM
94m6Z28's Avatar
Default Computer Or Leak?
started my car up today for the first time in about 6 months.
during that time it got some goodies. turbo kit. msd ignition and so on
today when it started it idles high. witch i expected but it wont idle down. it will sit at 1900-2000rpms...drop down to about 1100 then go back up to 2K.
now im wondering, scicne i had the computer tuned/ car being off with no power for so long. will it have to go threw a learning process witch could be causing this high idle/reving?
OR
do i have an intake leak some where? im not thikning i have a leak becuse my vac gauge holds dead steady at 20in at 2k, no fluttering no nothing
any ideas? im planning on tackling it in the morning and hopefully have it out eating 5.0 by dinner time
Old Jun 21, 2008 | 09:51 AM
94m6Z28's Avatar
come on guys, some one must have some idea
Old Jun 21, 2008 | 10:34 AM
06MonteSS's Avatar
LS1Tech Sponsor
if you had the battery disconnected during that time, then it may need to relearn stuff such as your fuel trims, which would affect the idle.
I know when I modify my tune, my idle is usually higher than normal for about 50 miles of driving...
after that it drops down to its normal level.
but like you said, it could also be an air leak somewhere that you created when you put that turbo kit on there... double-check all of your connections/clamps/hoses - make sure everything's tight and no leaks anywhere.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jun 21, 2008 | 12:53 PM
94m6Z28's Avatar
it idled high? as in its cold high, first start up high idle?
its been running for about maybe near two houres on jack stands well ive been bleeding the cooling system and fixing small things. a high idle is normal?
any thing i can do to help it (speed it up )or just let it do its thing?
Old Jun 21, 2008 | 01:17 PM
06MonteSS's Avatar
LS1Tech Sponsor
no, it's idled high, as in, all throughout my driving... not just when a cold start idle...
till I have about 50 miles or so on it....
then the idle drops back down to normal level...
idling/running on jack stands aint gonna do it.. need to drive it, so the fuel trims can be relearned...
__________________
Old Jun 21, 2008 | 11:02 PM
94m6Z28's Avatar
what are the chances of hurting any thing well doing this?
im guessing i just drive in normaly. i dont need to do the motor break in stuff do i?
some lower driving. some higher rpm stuff and all in between
Old Jun 21, 2008 | 11:09 PM
DaveX's Avatar
It's a turbo LT1 car? Or is it an LS1? The controls are very different is why I ask
Old Jun 22, 2008 | 03:23 AM
94m6Z28's Avatar
its a stock lt1 with things in sig
Old Jun 23, 2008 | 08:43 AM
94m6Z28's Avatar
...what does that mean?
Old Jun 23, 2008 | 09:28 PM
94m6Z28's Avatar
no one? i called to the tuner and he said it should be back at normal idle. ive driven about 40km*canadian eh* and its droped form 2k down to about 1500 and ive also got a small stutter at 2g and another one at 4grand, im wondering if its related to this wonkie high idle
any one have any ideas? i really want this thing to be normal again
Old Jun 24, 2008 | 06:58 PM
94m6Z28's Avatar
so no one has had this happen?? awasome...
Old Jun 24, 2008 | 08:42 PM
94m6Z28's Avatar
went threw and checked for leaks, sprayed break clean every where and nothing. checked TPS and its at .6X V at idle
going to go put a few KM on it here in a few min
does any one know what the little black box on the passenger side front fraim rail, besides the coolant over flow is? it has one vac line running to it. its about 7 inches long and maybe 3 inches tall in a log shape
Old Jun 26, 2008 | 08:51 AM
94m6Z28's Avatar
Checked and IAC and its in spec according to the chilton book. i plug the TB and it dies, so im 90% sure its not a vac leak, what els, besides the computer would mess with my idle this bad??
