a/c kills my idle.
I turn the setup on and the rpms slowly drop till it stalls.
What should I do to correct this?
You also may need to tweak some other things, depending on where you IAC is at idle without the AC on. Post the tune...........
If you jack that table up too high and the ITs go really negative, it can make the idle sag pretty good when the compressor kicks out and you are left with them quite negative but they need to be closer to zero, assuming your idle air had been properly tuned. They move pretty slow.
