EFI tuning
Old Jul 5, 2008 | 08:58 PM
johnnydje's Avatar
Default EFI tuning
Just got my efi live v-1 commercial,and wideband lc-1,just looking to get idea's where to start,98 camaro m6,any help would be thankful.
Old Jul 5, 2008 | 09:19 PM
TAQuickness's Avatar
Take a look in the help menu from the scan or tune tool under tutorial. Also, the EFILive forum is a great place.
Old Jul 6, 2008 | 12:20 AM
mvvette97's Avatar
there is alot of little tweaks you can do. Lean it down a little depending on how it's currently running, change timing, fan settings if you have a low temp stat, delete skip shift. Need any help just give me a shout. I also have EFI Live
Old Jul 6, 2008 | 12:29 AM
GMTECH4's Avatar
where do you delete skip shift at on efi live i have looked all over the place?
Old Jul 6, 2008 | 12:32 AM
shoemike's Avatar
{D0401}
Old Jul 6, 2008 | 12:36 AM
mvvette97's Avatar
yep, change to disable and your good to go. Don't forget to disable the lamp directly below also.
Old Jul 6, 2008 | 06:20 AM
DaveX's Avatar
What are your mods?
Old Jul 6, 2008 | 07:19 AM
johnnydje's Avatar
thanks guys,{researching all night}
Old Jul 6, 2008 | 09:02 AM
Bird's Avatar
Welcome to the club.
Be prepared to keep researching and reading - I've had mine now for about 4 months and initially, I was overwhelmed with the info available and trying to make sense of any of it (definitions especially). Have a friend with a dyno and we did the initial WOT tuning together - since then I've been working primarily on the drivability tuning on mine with the H/C/I/stall mods and it has really made a difference. Still have a lot to learn, but I'm making progress.
The search function in this section is invaluable and also on the efi live forum - there are many people here that have been doing this for years and have put out a huge amount of tips / info.
Old Jul 6, 2008 | 09:39 AM
GMTECH4's Avatar
Thanks!
Old Jul 6, 2008 | 10:49 PM
johnnydje's Avatar
its coming together slowly,talked to couple guys on here already.overwhelming is the word for the info,1 step at a time.
Old Jul 7, 2008 | 12:12 PM
SmaknaSS's Avatar
It is overwhelming at first but before you know it you find your self very comfortable with your self tunning. (For me that is).
