HP Tuners: Already have a license and asked to get another!
1 Post
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I had 8 credits on my HP tuners program, now it shows 6 and that I definetly have a license. When I try to write changes to the tune and/or car's VCM I get an error/Attention! message that asks me to get another license. I will not click it since it will use 2 more credits, which I have already used and registered properly. What can I do to correct this glitch?
Check to make sure that the license that your two credits are applied to matches the VIN of the vehcile you're trying to load, as well as VIN in the PCM, and the VIN of the File. You can do that by connecting the MPVi box to your laptop, opening HPTuner's Editor, click the little button that looks like a "dialog" balloon with an "i" in it, then in the new window that pops open, hit that button again. The only other reason it'd ask you for more credits is if you changed to one of the custom operating systems offered by HPTuners.
^^^ first check to make sure your VIN matches that in HPTuners
when I bought HPT I downloaded and installed the software before the cable was delivered. I opened up a few stock and modified tunes from hpt's forum and this forum and noticed it could be easy for someone not really paying attention to lock two credits to one of those tunes and that VIN number. Did you do something like this or did you download the tune from your car and apply the credits to that tune?
1 Post
I installed everything at the same time. I did not copy any tunes, the tune was done at a shop, then I bought HP Tuners and then had access to it to modify it. He did not lock his tune. I downloaded the tune in my car (not stock) and applied the 2 credits to it. We even tried saving it as another tune and it does not work this way either. I just don't want to use 2 more credits. HP Tuners wants a scan log every time something goes wrong and this is costing me too much time not racing at the track.
1 Post
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
If the shop used one of the custom OS's such as the Enhanced SD or Enhanced MAF OS's. If you want, email me the file you have and I can take a look.
sales@1320hp.com
sales@1320hp.com
LS1TECH Sponsor
It could be one of several things that is causing the issue, if you send the file our software is asking you to license along with a vcm suite infolog while connected to the vehicle in question to support at hptuners.com we can easily determine what the issue is. You could also post the files here and I'll be more than happy to look them over via the forum
Thanks,
Bill
Thanks,
Bill
My bet is Custom OS. Click on Calibration Details for info. Your Tuner might have applied a 1 Bar SD tune or different. Click on the HP logo on VCM Editor and you can see the different OS options. if one of them says licensed then you need two more credits
. Unless you get your stock tune and do a WRITE Entire.
Correct me if i'm wrong guys.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
LS1TECH Sponsor
