HP tuners and scaning non LS1 engines
Hi
You know how it is. My girl friend has a 2003 Mitsubishi Outlander. It does not want to go when cold. I would like to scan it with HPT. Any body try this? Will it work
Thanks
Thanks
I don't know but I hear you.
Friend had a 96 f150 throwing a code the other day and I couldn't even read the code out with HPtuners, but I can with a cheap CAN handheld scanner.
WEAK!
According to HPT I think you can scan any vehicle they support just not edit anything. So guess just find out if they support that vehicle. Being it's not a performance one I would guess no.
WEAK!
http://www.hptuners.com/products/vcmsuite_vehicles.php
Mitsu or the 96 Ford is not on the vehicles list so it won't scan them. I'm guessing the scanner can't interpret the OS on the other computers. This isn't a negative on HP Tuners they developed software for recent GM and Ford computers and interpreted the signals. It's much harder then you think to do this as the manufacturers try to stop this from happening I can't imagine what goes into doing this. It's basically hacking and reconfiguring the PCM. And you don't buy parts for a honda and expect them to work on an LS1 do you?
OBDII is an industry standard. One of it's purposes IS to be able to have known outputs so handheld scanners can read certain data like CEL's. That's why you can go to walmart or autozone and buy a $30 code reader and it works on any OBDII vehicle. If a $30 part from walmart can read any OBDII vehicle, I think it would be pretty easy for any of the tuner companies to add the same ability to read CEL's from any OBDII vehicle.
Were not talking about writing or editing the PCM, just reading/resetting trouble codes.
Something I would really like to not have to keep my second CAN-II around for.
