hp tune rev limiter not consistant
Old Sep 15, 2008 | 01:42 AM
js2fst's Avatar
Default hp tune rev limiter not consistant
We have the rev limiter at 6800 sometimes it comes on 5800 6000 6600 we just do not know how to stop this.
Old Sep 15, 2008 | 02:51 AM
1987firechicken's Avatar
Did you change it right below the "RPM limits" under engine > fuel control > Fuel cutoff under "P/N Cutoff" and thats it? Below that there is a Cutoff RPM vs. Gear table that has a limiter table in that as well. If you haven't looked at it give it a look.
Old Sep 15, 2008 | 07:11 AM
mikey's Avatar
LS1TECH Sponsor
Also, make sure you are not running into the cold engine limiter.
Old Sep 15, 2008 | 10:11 AM
Frost's Avatar
I have never seen this behavior when properly setup, post the tune and log of incidence so that we can have a look.
Old Sep 15, 2008 | 10:59 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i agree
Old Sep 15, 2008 | 12:44 PM
BuffJoeyD's Avatar
Post the tune-
Are you logging these rev limit points , or are you going off the factory tach?
Old Sep 15, 2008 | 11:12 PM
js2fst's Avatar
factory tach next compare with laptop. Thanks for the ideas, most are fine looking at another 2
Old Sep 16, 2008 | 11:06 AM
Frost's Avatar
Yeah, the factory tach is nothing to compare against; especially in the lower gears.
I had a customer keep tagging a 7K limiter last friday night at the track for his 1-2 shift while his tach read 58-6000...
