What to get/buy for my ls1..
Old 03-17-2009, 11:00 PM
cjvmboricua08's Avatar
Default What to get/buy for my ls1..
ok i'm going to the army pretty soon and i wanna have a list of what i want for my 2002 trans am so i can do all this while i'm gone.. i want it to be straight motor no Nos. I need opinions on what all i should do in order to get my car running the fastest at the track and at the same time be street driveable.
Thanks!!
Old 03-18-2009, 01:03 PM
Spd-Kilz's Avatar
This is likely what I'd do:
Do all of your free modifications first.
-TB Bypass
-Cut lower lid assembly
-Remove AIR
Parts:
-Aftermarket Lid (SLP, MTI, etc. etc.)
-Long Tube Headers - Race (no AIR fittings)
-Off Road Y Pipe (no cats)
-Electric Cutout
-Stall Converter (if A4)
You're looking at spending about $1000 on all of those parts - clearly depending on what brands you buy.
Old 03-18-2009, 01:06 PM
sanya_kim's Avatar
depends on how much money you want to spend
408 is what i want to do, and moser 9"
Old 03-18-2009, 01:22 PM
Spd-Kilz's Avatar
Hah! That's an option too.
Although judging by the lack of information in his post, I'm guessing he doesn't want to spend several thousand dollars
Old 03-18-2009, 06:23 PM
haha maybe i should of added the list of stuff done to it already!! and also that i'm going into the army if i didn't already say that.
mods already done to the car:
TR 224/224 .563/.563 112lsa
hardened TR pushrods
tit. retainers
918 springs
LS1 Edit
double roller
TCI 3,500 2.5 stall
160* stat
Pacesetter LTs coated
Pacesetter ory pipe
SLP loudmouth w/3.5 tips
p/p stock TB
SLP lid w/k&n
!AIR
Optima red top
QA1 12 ways (4)w/ 325 springs
UMI panhard adj.
UMI Lca's non adj.
UMI strut tower
MIDWEST fabbed 9"; strange alum center,drain,braced, detroit tru trac,31 spline axles moser,1/2" studs,tcs/abs,lca relocates,motive 3.70, just installed in late march, has about 700 mi. on it.
Strange chromoly driveshaft
MIDWEST tourque arm/chromoly w/ shortened tunnel mount
3" 12mm studs for front
powerslot rotors (4)
TCI line lock
Walbro 255 intank pump
B&M trans cooler
TR55's w/msd wires
ZO6 replicas- 18x9.5 17x9.5
Old 03-21-2009, 06:12 PM
help please!!
Old 03-21-2009, 06:26 PM
Spd-Kilz's Avatar
Nice list of parts.
I'd probably do:
-Nice set of heads (TFS or AFR)
-FAST 92/92
-Drag Radials
-Ported LS6 Oil Pump (or better)
Old 03-24-2009, 01:24 PM
Jrod RF's Avatar
Get some heads and cam of course its a common thing to get a nice boost. OH! and get it tuned!!!
Old 03-26-2009, 08:29 PM
yea i've been looking at different websites like texas speed and vengeance racing. what i plan on getting is intake, tb, bigger cam, heads, draglites, then going radial on my z06 reps. What i'm still deciding is on the gears.. what would be the pros and cons of goin 4.10 from staying on 3.70's?
Quick Reply: What to get/buy for my ls1..
