Small (hopefully) problem with my T/A
I put this in the general maintenance section and didn't get any responses so hopefully someone here can help me out. I have a 00 T/A A4 with just under 30,000 miles. When I'm just driving this thing normally like a sane person I have no real big issues with it, runs and drives great. However, when I really get on it and put it at WOT or a little less, I get this ticking sound (best way I know to describe it really) and when the car switches to the next gear feels jerky/sluggish. Went by O'Reilly's and ran their diagnostic tool on it and got a misfire on cylinder #2. Forgot to write down the damn code #s. First thought was to just get new plugs and wires, but if it was a plug or wire wouldn't I notice it at low rpms and normal speeds just like I would when it's wide open too? If it sounds like I'm hard on this thing I'm really not, but I do like to have my fun occassionally and open her up. Basically just looking for some Idea's and too see if anyone has experienced anything similar. Want to get it fixed and try not to break the bank at the same time. Once again, it's fine just normal everyday driving, only when i open it up and get above 3,000 rpm or so do I notice the sound and the jerky feeling. Thanks guys. Appreciate any help.
What kind of ticking? Like metal on metal or like a loud stop watch? It could be a number of things, but a good place to start is with plugs and wires. You may have a plug that is getting fowled out or a wire giving too high of resistance. Its hard to notice a misfire on a V8 at lower loads, at high load is where your really going to feel one cylinder misfiring. Start with plugs and wires see if that clears things up.
Wires and spark plug issues are more likely to show up under full power. I would say that you need new wires and plugs at the same time. A bad coil will also make itself known when under WOT power. The car can cruise around just fine, but when you need the power the extra spark is lost. The noise you hear is the spark jumping to ground.
Misfire code on #2 means that's where you look, but change them all. Plugs and GOOD wires.
More of a stopwatch like ticking. Doesn't sound like metal just kind of a clicky sound. My first thought was plugs/wires so hopefully that's what it is. Having it checked out tuesday by a local guy that's supposed to be pretty good with these things. It would bother me more if it did it all the time but like I said only when I really get on it do i notice the ticking sound and sluggish performance. Appreciate the help. Any advice on quality plugs and wires if that's what it turns out to be? Half the time I hear stick with OEM, half the time I hear NGK plugs with MSD wires just want to make sure I dont buy junk.
While you're taking care of the plugs and wires, I would recommend that you also stay away from Shell gas. A while back, it was reported that many car owners had their engines damaged from a sugary additive in their gasoline that messed up the powertrain. A class-action lawsuit was filed; I don't know who prevailed, but I would assume justice was served.
Ticking sound may be a bad wire. At night, very dark night, take a windex style bottle full of water and lightly mist around the wires and plugs with it running. If they start "glowing" then that one is bad. Make sure you use dielectric grease when you put hte news on.
The only other article I found referred to marine engines and fiberglass tanks, and was not unique to Shell.http://www.lawyersandsettlements.com...hanol-gas.html
Ok, I agree, this sounds to me like a wire, but it may but that one of your wires has shaken loose from the plug. What I would do is make sure all of them are snapped in good until you feel the wire "CLICK" on both the coil and the plug..... The reason you wouldn't hear it at lower rpm is because there would be less "clicks" and probably not as loud.
Start with wires, and if you find a wire that was burned or damaged, chances are you need to replace that plug, because it could very well have fouled the plug by not firing right.... This would usually make it idle a little "choppier" too and if its a wire/plug after the fix your fuel mileage should go up a little.....
Really just sounds like a loose wire to me.
Another thing to check is that your plugs are tight. Had a guy at work change his and a couple of weeks later, he had a ticking noise and the rear one on the right side was loose. You could actually see it moving back and forth as the engine was running.
You may have just had a wire come loose and it's arcing somewhere.
Got headers? Could be a burnt plug wire? Ticking could also be an exhaust leak.
Just throwing stuff out there for you, but I would start with plugs and wires first as well.
