What was the best 4th Gen Firebird (98'-02")?
What do you mean by best? Ignition changed the second year, this seems to be the biggest deal, performance wise. Then the casting process for the heads changed, although the heads themselves didn't change too much..Casting number for the old heads was 853 the new ones were 241, there may be a very minimal performance gain ( 5hp? ). Then for the final two years there was a new intake manifold, the LS1 intake was replaced by the LS6, and even though the LS6 intake was a better performance piece significant performance increase was negated by a smaller cam.
Besides that, there was a wheel change at the end of the run... and some small cosmetic changes to the interior if I remember correctly.
Really, the difference is so minimal I don't think there's a best year...
Agreed, if by best you mean most updated, then go with the last two years of production as they had the new heads, new ignition, new intake, as well as small interior updates. If I remember correctly, the last two years were also the most produced so should be easiest to find and most likely to have the lowest miles.
Location: Your girl's back door giving her the long stroke while you're at work
Here are the changes by year
https://ls1tech.com/forums/1740880-post2.html
Specific 01-02 changes
https://ls1tech.com/forums/1740881-post3.html
