Turn signal question for WS6?
Here's a writeup on how to change the socket without cutting and splicing any wires:
https://ls1tech.com/forums/11115320-post8.html
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
A much easier solution is to simply clean the socket with electronic cleaner spray (available from any auto store), and then fill up the socket with di-electric grease before re-installing the bulb.
Mine's been working with that fix for 4+ years now with no problems.
IMO, the big reason to switch to LEDs is for lower heat so you don't have the discoloration and cracking of the DRL housing. Only time will tell how well the conversion has worked.
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
Bought my 99 TA a week ago, redoing all lights, already $380 ordered. Had to replace the passenger front turn signal bulb, load was goofy and would only blink every 10 seconds. Now works fine, it off loaded the drivers side and replaced both, all works good... EXCEPT, the passenger side DRL is not working, but blinks just fine when the turn signal is on. Will be purchasing new socket tomorrow to replace due to slight corrossion on present one. Should this fix it? Tired of feeling like an idiot who can't take care of my car because I drive with one DRL
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Thanks
Jared
