PROJECT "UNLEASHED" (My 99' Trans Am)
#182
Lol. Yeah I understand bro. It's not much of a Daily Driver to most bc of the cage, solid rod end suspension, and loud *** exhaust. Lol But I have plans of doing a different exhaust setup this winter. It's getting borla xr1 mufflers and true 3" duals over the axle and out the back of the car.... My buddy is gonna do them for me. :-)
#183
Ok, so I just wanted to post up a few videos for everyone to see.
Rather than reposting them here, here is a link to my Street Racing Thread. ;-)
The car is running good now (on the street) But still needs some more tuning and suspension tweeks before it can run a good ET at the track. We are currently having issues that only occur on the track and hope to have them all lined out before the end of the season.
Here's the Link.
Enjoy!
https://ls1tech.com/forums/street-ra...l#post16771193
Here's the Link.
Enjoy!
#187
Thank You. I will definently keep this thread updated. I still have a few more parts to install, tuning to do, and some test n tune nights before the end of the year...
#190
Well I finally got the Transmission tuning finished up on the car now.
And started having Idle issues. Turns out My Wideband Bung Blew out taking threads with it and the O2 Sensor is going Crazy. Gonna fix that this weekend.
Also, The car started doing some crazy Backfiring and dying **** again. Turns out the ARP Cam Bolts had started backing out of the cam.
Thank God I had the Cam sensor in the front timing cove bc it started setting a cam sensor code and I replaced the cam sensor and thats when I found the cam gear was hitting the cam sensor and causing it to lose signal. Thus causing the backfiring and dying issues. So I tore the front of the engine down and fixed the problem and now it is running great again. I'll tell you "Loctite" is your friend.
I have plans on getting to the track and tuner 1 more time before the end of the year. Wishe me Luck. :-)
Hopefully there are no more issues before I put the car up for Winter.
I will post more info on the car and update this thread some more very soon.
-James
-James
#193
Update:
Went to the Track last night to get in some more test passes. First Pass was my Best.
I was leaving very easy just to get use to how the car liked to leave, and be sure it wasn't having anymore issues on the big end. It ended up having another issue on my last pass. Cam sensor issue - AGAIN. Grrr
But still Very Pleased with how well it ran considering I was leaving Very Soft.
New PB is...
10.555 at 128 mph with a 1.47 60'
Managed to pull both wheels about a foot off the ground on my second pass, but the camera was pointed down the track and therefore didn't catch my launch.
But I was Racing the RPM Transmissions Shop Car - White 5th Gen Camaro, So I was ok with that. lol I seriously " Love " That Camaro.
Here is a compilation Video of My test passes for the day!!!
http://youtu.be/o3-PAO5sbno
New PB is...
#196
I bet, I can't wait to get back and get mine to the track... I won't even come close to yours but still getting some numbers will be nice haha. So what's next? I know the thing is pretty damn close a drag car I mean hell at light throttle off the line your only a sec and a half off there shop car.
#197
Yeah I Am Very Pleased with the car as it sits right now!
I am just gonna add a few gauges, the new hood I have for it needs painted and installed, and then just gonna finish working out all the minor bugs with the car and then I will be hitting the track alot more often next year and hopefully get the car as close to a 9 second pass as I possibly can.
I have been contemplating on pulling some more weight out of the car and seeing if I can get it into the 9's for sure. I know the car probably has it in it now, But if I cut more weight it would be easier to achieve.
Other than that I don't really have any more plans right now. I just want a 9 second NA pass.
And I wish you luck with yours as well. lmk what it runs when you do get some track time in.
#198
Update. Will be removing the front and rear crash support stuff and door bars and relocating the battery to the rear of the car as well. Gonna try to lighten it up just a little bit more. I'll post pics later on as I actually do work on the car.
Hoping to get it all 100% before the TX2K13 Event.
