Air conditioning issue. HELP!
For my 99 Trans Am, the A/C will not start blowing cold until I've allowed the engine to run up to at least 4,000 RPM. After that, it works just fine blowing cold air non stop. Turning the A/C or engine off and it happens again-no cold air until I rev up the engine.
I've checked everything obvious, nobody I've spoke to has ever heard of this.
HELP!
I'll have to have the system checked to tell you the pressures at idle.
The compressor is about two years old, it didn't do this when it was first installed. I don't think any parts of it are worn, it's an AC Delco rebuilt unit. I also doubt the charge is low, when it works it's pretty good and cold.
I replaced the original compressor because (while over tightening a bolt) I cracked it's body.
like the first response said, the compressor is having efficiency issues. have a good AC shop check it out, and have them do the repair properly. AC work is easy to do wrong, and often problems don't show up until later. having someone do it properly will save you money in the long run!
I'm starting to believe you guys, the compressor is junk.
I'm not gonna invest in A/C charging stuff when my buddies body shop has the full sized cart to suck the stuff out then re-charge it properly.
According to GM, the compressor number is 1137028 and listed at a zillion bucks. I did find it new from autopartstomorrow.com for $361.
Is this the way to go? Correct compressor or is there a "trick" compressor you guys might know about?
Paul, make sure you also replace the accumulator and orifice tube.
