93 bird
Old 08-18-2011, 01:38 AM
astan84's Avatar
Default 93 bird
My 93 bird is misfiring. Did plugs wires fuel and air filters. Any ideas?
Old 08-18-2011, 07:16 AM
TechCam97's Avatar
Probably your opti.
Old 08-18-2011, 01:37 PM
astan84's Avatar
What is a opti?
Old 08-18-2011, 02:54 PM
TechCam97's Avatar
The optispark is essentially your distributor. When they get fouled up, you get misfires like crazy. Replace yours with a vented 95-97 style and it helps the longevity. Do a search and you'll find more info than you can shake a stick at.
Old 08-20-2011, 12:41 AM
astan84's Avatar
Did some research... Hope that fixes my problem.Expensive part!! Thanks!
Old 08-20-2011, 05:54 PM
Ocala93TA's Avatar
Was it misfiring before the plugs and wires ? if not recheck all your wires are installed correct
Old 08-21-2011, 09:37 PM
astan84's Avatar
yes. thought that would fix it but it did not.
Old 09-19-2011, 11:52 AM
astan84's Avatar
Default help! 93 bird
i replaced the cap and rotor and now it wont run at all???
Old 09-19-2011, 12:08 PM
Ocala93TA's Avatar
Go over it and make sure everything is plugged back in correct , did you take it off an put it back correct ? When you took it apart did you use locktite to put the screws back ?
Old 09-19-2011, 04:48 PM
astan84's Avatar
Would NOT using the locktite keep it from starting? Everything else seems to be in it's place and secure. Could I have messed up the time?
Quick Reply: 93 bird
