96 TA rough idle
96 TA rough idle
My TA is running terrible and i've done numerous things... tune up, vacuum lines.... everything i can think of. I think it's one of the infectors, cuz i got a miss on 1 & 8. Any ideas on way it could be plz let me know.
Didn't do the opti, But I did open it up and check inside. There was alil oil and coolant inside (on the bottom, but not alot), and the pins had junk on them. Cleaned it all up and put it back together. Also changed the opti plug (the power wire). Now it's throwning a P0336 code and a local shop said to put that wire on so I did. Havent driven it yet so we'll see.
Has anyone seen any rims for sale/trade? I have these Z06 rims and looking for some ZR1 rims, want some staggered rims... It sets off the car to me, that muscle car look ya know.
All but two O2's are new and it does throw a O2 sensor code every one in a while. Probably going to just get those two and then they will all be new. I was told to replace them in pairs.
I got a modis snap-on scanner and I can see the misfires and it is randomly misfiring and the P0336 code pops up every time I start the can, but if I clear the code it doesn't come back till I cut the car off and restart? If this helps I did the timing chain, timing seals, and new gaskets. Not sure if that means anything.
It does seem to go away once it's warm, but I think it has something to do with the crank sensor. Like I said I also did the timing chain a few months back also, maybe I didn't put the crank sensor in right (well the shop I took it to did it). IDK
