Stock 98-02 WS6 1/4 Times?
Manual Transmission 02 WS6, significance being I had the LS6 intake from the factory.
Car had 86k miles when i took it to the track.
I'm not the best shifter in the world.
I had a 2.2 60 ft and pulled off a 13.6 @ 108 mph.
With traction and slicker shifting it should've been a lot better.
The car traps high for being a stock car.
I will make it out their next year hopefully with drag radials and better shifting. Since that best run, I have added a GMMG exhaust and an SLP lid along with a shorter throw shifter.
All I have is a lid and suspension and my best run has bee 14.1 @ 103. Low profile tires + bad track prep = spinning for 1-2 seconds each launch. Although it was probably my fault I was gunning it too hard off the line, was my first time drag racing my own car.
1998 Trans Am automatic 3.23 rear and 3800lbs raceweight
13.408 @ 103.75 w/1.978 60ft bone stock 87K miles
12.712 @ 109.45 w/1.925 60ft with lid, LS6 intake, headers, exhaust, and drag radials 92K miles
12.080 @ 110.05 w/1.568 60ft with SS4000 converter and 3.73 gears 95K miles (current setup)
