99 formula surging under light acceleration
hi guys new to the forum just got a 99 formula auto 116k miles car has slp lid k&n magnaflow if i accel very lightly car runs good full accel runs great middle accel it chugs and lurches i have already changed plugs to factory ac delcos new wires fuel filter and o2 sensors no codes current maintains no vaccum leaks(did smoke test) 56 - 59 lbs of fuel pressure if i install my superchip program it won't get out of its own way
any suggestions would be great
thanks in advance
thanks in advance
is it throwing any codes? I had a similar symptoms with my car when I first got it.. it would studder and backfire, ect. turned out to be the crankshaft position sensor right above the starter.
I had the same issue...it's your MAF...unplug it and drive it..that will let you know if thats the problem or not. I ended up going with a 85mm off a Z-oh...and car feels like it gained 30hp.
thanks and not throwing any codes maf is clean and screen is there yes change fuel filter when i changed the plugs and wires
