If your thread is gone, look for it here...
Coolant level light
Random Miscellaneous Mechanical Issues
Instead of random posts about miscellaneous mechanical issues in the Firebird-specific forum, try and get a diagnosis of your problem(s) in the General Maintenance & Repairs FAQ sticky. If you can't find a resolution to your issue there, then feel free to start a new thread.
Thanks for your cooperation,
Scott (y2k_ta)
I have a 1999 Firebird Formula with 182000 miles. This car runs like it is brand new and i am the second owner. This car has never had any serious issues at all. But i went through the car wash the other day and shortly after leaving, my low coolant light came on. So i went and put some coolant in the reservoir and took it home, waited till it cooled, opened the radiator and changed the cap .the radiator and reservoir were full. The car does not overheat, run rough, smoke, no real bubbles in the coolant, nothing. So i ran it the other day till the light came on, carefully removed the cap off of the radiator with it running and found that the level had dropped. A few seconds later the level rose and i put the cap back on. I'm guessing the level dropping is due to thermostat regulation. So i am going to replace the level sensor next due to the fact that when the level rose back to normal (while the car was hot and still running) and the light never went off. Anyone ever run into this? what are yalls thoughts. Last resort is pulling off the heads and checking them and the gaskets. I just was wondering if i am missing something.
Scott (y2k_ta)
Front turn signals
My front turn signals don't flash at all ( rear ones work fine ) and I've read in a few different places that this happens because the sockets corrode or rust out and the best option is to replace them since they only cost something like $8. Also, the DRLs don't work either, which I believe is a separate issue altogether but I'm not really concerned about those.
I found a thread where one of the users said that they are the same part as LT1 Firebird tail light sockets ( which coincidentally, the part I linked below has the same part number as the tail light socket for my 99 )
http://www.autozone.com/autozone/par...5_148677_4155_
Is this the correct part?
if you have the patience, rockauto had them on sale not too long ago. I got 4 sockets for like 15 bucks shipped.
If your lenses are cracked, you can replace the bulbs and sockets, but they will only corrode again in a couple months.
Heres my thread.
EDIT wrong thread
The last post #32 shows what i bought to fix the problem.
Heres my thread.
EDIT wrong thread
the problem is the poor design by gm, the filament bulbs get to hot, and melt the housings, causing water in, corroding the sockets. Get new housings, replace the sockets, and put in LEDs. problem solved.
i just noticed i put the wrong thread in post 3.
If water is not getting inside the housing, then a new socket probably isnt going to fix your issue though. Have you already replaced the bulbs only?
Just for clarification. The front signal bulbs do not flash when using the signal or hazards. They illuminate just fine if I turn them on via the headlight/parking light controls. The rear signals flash just fine. The arrows on my dash are working correctly and do not flash irregularly or stay solid.
I haven't replaced anything yet. I came across a thread on here where the OP had the same EXACT issue I described in the first post. He had to re-solder the DRL module along with getting new sockets and bulbs. Completely fixed it.
I'll be looking to replace them this weekend ( or whatever I have to do ) to get the turn signals working. Like I said before, I'm not really that concerned with the DRLs.
I wouldn't even have known they were out if my girlfriend hadn't asked me why I wasn't using my signals when I was driving behind her. Theres absolutely no indication that the front bulbs aren't flashing from in the car. The dash arrows blink just fine.
I just want to fix them so I have 1 less reason to get pulled over ( though nobody I know in my area has EVER been pulled over for not using a turn signal ) but wost case scenario, I'm willing to bet I could get off with a warning if I show the officer that theres no indication from inside the car that my front bulbs don't flash.
Edit : I have an aftermarket keyfob ( PO installed a remote start ) and when unlocking/locking the car with the fob, none of the exterior lights or horn do anything ( Interior dome lights come on when I unlock it ), so using that as a diagnosis procedure is out. Its more than likely set in a different mode than default. I have the owners manual and I saw something about unlock/lock options in there when I was skimming through it.
I fixed my 98TA turn signal problem once I realized the cause. The T/A housings have a lens on the front that is in 3 pieces. They are not glued or fused together originally so water will leak inside whenever you are driving in the rain at any real speed. I couldn't believe it when I did a pressure test on them and saw the water leaking out the 2 vertical seams in the lens. Coating the entire front of the lens with clear epoxy fixed the problem.
Also regarding the flasher not changing speed when the front lamps were out, that is because someone replaced the original thermal flasher with an electronic "heavy duty" one that is not sensitive to a changing lamp load. You have to be careful in selecting a suitable replacement.
good luck man, i just had my own turn signal problems and it took me half the day to figure it out... when i was driving to get parts every time i saw someone use there turn signal it was like they were mocking me...
common power steering leak areas
So I think I've figured out why my alternator seems to work sporadically. I'm pretty sure I have a slow leak from the ps onto the alt. When I took the alt off a whole back to get it tested even the guy thought it was kinda oily with a residue. Well that same weeki also filled my ps reservoir. Well now my reservoir is low again so I'm thinking that I can kill 2 birds with one stone if I can fix the leak then maybe the alt will work better
Not the car wash
those I could have bought one from the dealer. And it stayed off for months and came back on a few weeks ago.
04' blinking radio display
What exactly is the cause of the monsoon blinking display. Seems like if I leave mine on for a while it clears up, kinda like there is moisture in the internal wiring.
