Making Sure I Have My Ducks In A Row
I am making sure that I have everything I will need when it comes to my installs this spring on my '02 WS6 so I can keep an eye out for anything I may need to get that comes up for sale.
I am going to be lowering my car on Khonis and BMR springs. I plan on doing the heater hose mod on the rear before they get installed. I also am getting an adjustable panhard bar and LCA relo brackets. I will also have them check out any bushings that may need replaced. Anything else I am missing?
I have a Yank SS3600 stall and will be getting an aftermarket cooler to keep the trans temps down. I will also be looking into a shift kit at the same time. Anything else needed here?
I will be getting Speed Engineering race headers with my bonus which will be going back to the ebay true dual system. The guy I am trading has it dumped before the axle but I am going to be running it over the axle and out the back to 4" corsa clone tips. I have been reading that going 3" over the axle can be a challenge for most shops so if they cant then I will just go with 2.5" pipe over the axle to the tips. I have poly motor mounts in the clams to go on at the same time as well. Anything else?
I will be getting everything dyno tuned in Columbus as well.
Thanks for any and all input!
You need synthetic grease for the bushings in the panhard bar. I would skip the heater hose mod and keep the bigger rubber insulators. Im on Konis with Strano springs, and it sits pretty low already. I wouldnt drop it any more with duals. I would do the spark plugs also.
if you're doing panhard and lower control arm relocation brackets then do the lower control arms aswell don't go halfway. and plugs and wires while you have them pulled apart for the header install just makes sense (thats what I've been planning).
When you lower the car you will also need an alignment.
If you insist on having aftermarket LCAs, then just make sure they are not poly bushings as they will bind.
With relocation brackets you can adjust the angle of the rear LCA which can help with traction but will hurt handling (its actually better for handling that he rear LCA body side to be lower than the axle side, just like it is when lowered).
What do you want to get out of the car? Just a street car for toying around? Are you more concerned with drag racing? Handling? Ride quality?
The car is only driven on nice days. It won't be autocrossed. It may see the drag strip once or twice a year so I'm not real concerned with that. I am looking for ride quality mostly because we don't have a lot of curvy roads around here to mess around on.
When talking to Founders they recommended these LCAs
http://www.foundersperformance.com/1...ce-poly-joint/
Thoughts?
Thoughts?
