Problem while changing my oil.
Old Sep 12, 2014 | 09:33 PM
FireTA99's Avatar
Default Problem while changing my oil.
I was doing my oil change and I was going to change my oil filter as well. I unscrew the oil filter and when I go to loosen the bolt to get the rest of the oil out I couldn't do it. I used all of my strength trying to loosen it but I couldn't. What do I do now?
Old Sep 12, 2014 | 10:59 PM
Kevin Lee 487's Avatar
Find someone stronger?
Maybe push on the wrench/ratchet w/e you use with your leg instead?
Old Sep 12, 2014 | 11:27 PM
Dutch7's Avatar
Shouldn't be that tight. You turning it the right way? Don't force anything or you will strip the bolt then it really wont come off. Try getting a wrench and wiggle it a bit? Unless someone overtightened it before you it should be no problem.
Old Sep 12, 2014 | 11:44 PM
M4N14C's Avatar
Make sure your loosening not tightening. When I changed my O2 sensors I was working for 20 min on the drivers side going Hulk mode before realizing I was trying to tighten it
If you're sure your loosening, do you have a rubber washer between the bolt and the pan? They can come off and some people unknowingly just screw it back on.
Old Sep 13, 2014 | 12:16 AM
Mildphil's Avatar
Im assuming you didn't do this while the car was hot, but as stated above maybe you are going the wrong way? If you are doing it correct just try harder, sometimes the bolt can get stuck if tightened too much previously.
Old Sep 13, 2014 | 09:51 AM
FireTA99's Avatar
Is this really the problem? I did do it while it was hot.
Old Sep 13, 2014 | 10:14 AM
madmike9396's Avatar
start working out bro !
take a hammer and tap the wrench lightly making sure you are loosening the bolt and not tightening it.
Righty tighty
Lefty loosey
Old Sep 13, 2014 | 10:21 AM
eseibel67's Avatar
Righty tighty
Lefty loosey
This is it. To avoid damaging the bolt head, a sharp blow is always better than a slow pull when loosening tight bolts.
Old Sep 13, 2014 | 11:14 AM
FireTA99's Avatar
Righty tighty
Lefty loosey
I do work out. The damn bolt wont budge. i tried for about an hour. I'm thinking they tightened it too much at the place that the oil was changed at. I think i'm going to break the bolt off and put a new one in.
Old Sep 13, 2014 | 11:16 AM
FireTA99's Avatar
I know i was doing it correctly because i couldn't even tighten it either. i tried both left and right and it would not move.
Old Sep 13, 2014 | 11:39 AM
Mildphil's Avatar
Talking
Wait until it is cool because for one it can be dangerous while hot, and two the metal could have expanded and locked the bolt in tighter, but that is a theory because I have never changed oil while hot. If you can't get it off still here is what you do, spray a little WD-40 around the bolt, not too much but enough to seep in. Then grab your ratchet and see if you have a spare piece of strong PVC or metal pipe around, and use this for more leverage by putting the shaft of the ratchet inside it. You can also hit this pipe with a mallet if it still won't budge, but the extra leverage should make it a lot easier.
Old Sep 13, 2014 | 12:02 PM
SSickLS1SS's Avatar
use 2 wrenches to give you more leverage. put one wrench on the bolt and then put the other wrench on the opposite side so you interlock them and make it twice the length. that should do the trick.
Old Sep 13, 2014 | 12:26 PM
wssix99's Avatar
Save the manuals!
How about a socket and breaker bar?
Old Sep 13, 2014 | 01:15 PM
FireTA99's Avatar
I'll try it when the car is cool.
Old Sep 13, 2014 | 04:22 PM
MaSTi's Avatar
Breaker bar/PVC for leverage works wonders!!!
Old Sep 13, 2014 | 05:53 PM
+1 on the 2nd wrench to interlock. Used this trick when I worked at an oil change place.
Old Sep 13, 2014 | 08:14 PM
Dino1's Avatar
Do it while it is stone cold, I have a quad that you can not remove the drain plug out of the aluminum case when it is hot. If you loosen it cold it turns very easy. Aluminum has a large thermal expansion rate and the plug is tightening up when hot.
Old Sep 14, 2014 | 06:53 AM
the dumb asses that changed it probably put it back in with a impact tool.
Old Sep 14, 2014 | 07:35 PM
FireTA99's Avatar
I think they did. It was on so tight.
Old Sep 14, 2014 | 07:38 PM
FireTA99's Avatar
Update:
I finally got the bolt off. I waited till today. Sprayed some wd40 on it and let it sit. I got a hammer and rachet and I got it off.
