help with 4th gen TA Wing
can someone please tell me if the 4th gen trans ams have gaskets on the rear wing between the trunk and the wing itself and if so, wherecan I buy them I searched everywhere but cant find anything for that please and thank you
This is true...its like a foam pad thing that goes around the hole that the third brake light wiring goes through and there's also some kind of rubber epoxy sealer glob looking stuff on each of the studs on the wing
I used neoprene and cut to fit. $10 for a sample, shipped, did the trick: http://rubbersheetroll.com/samples.htm
That's MISTER MODERATOR
There appears to be sealing washers that go over the bolt holes between the spoiler and the deck lid, it's used in a zillion applications and still available, GM number 20733729. Even Summit lists it.
There's another seal, it may be the one for the wiring. Not sure if you'll find it: 20733729.
