picking up a firebird
something else you need to mention is whether your looking for v8 or to save some money with a v6 as with a v6 you want to be 00-02, the 98 still had the angled throttle body(from the earlier body style) and the 99 still had the log style exhaust manifolds and is really hard to find a tuner for, you pretty much need to send that one off to get tuned.
If you're looking for a 4th gen, 96&97 are the best choice IMO if you're looking for an LT1. 93&94 still used OBDI and didn't have vented Optis. 95s used a weird OBD system, 96+ uses OBDII with vented Opti.
As for LS1s, I'd say either a 98-99 or a 01-02. 98s didn't have a bunch of little cosmetic and functionality issues that 99s and up have ( cracked door panels, trunk spring being too weak, fading sail panel, etc. ) but they use different PCMs and wiring than the later years.
2000s still had the LS1 intake but got the smaller cam or " truck " cam. 01-02s got LS6 intakes, slightly better heads and a smaller cam to shift the power band lower.
Watch out for headlight motors. You'll probably have to replace them.
1. She will probably need valve guide seals she has some bluish smoke so I know some oil is seeping past the Valve and into the cylinder..
2. Ttops do leak when it rains really really hard
3. Exterior has clear coat fading
4. drivers side door was broken into, but I'm including new doors so that doesn't matter
Now for the good, She has always run Wix Filters, Mobil 1 5W-30 Full synthetic, Plugs are double platinum Bosch's recently changed, Pioneer head Unit, Kenwood 6X9s, New Ttop bag, New doors included, New Dash Pad included, new ignition control module, new coil, new wires, Fresh Air Filter and two tires
Mileage is 156K is a 5 Speed, all dials and gauges work perfectly fine... Never overheated shoot me an offer
this is the post! i dunno what do yall think? for 850
