Required CCAs for 2002 Firehawk?
Went out to a dead battery, so I'm in the market for a new battery. I put the charger on it and it starts, but I don't know how old this battery (Napa Legend) is and its obviously not up to not being charged regularly...
So It looks like a group 75 battery, but with what CCAs? And what brand is everyone running or which one would be your next battery?
Firestone has a coupon for an Interstate Mega-Tron II for $99.99 good until the end of the month, so Im leaning that way.
TIA
TIA
Thanks, I've had the Duralast Gold in other vehicles, and have had mixed results.
That Firestone coupon isnt all that great of a deal, they take $20.00 off the cost of the battery but you have to let them install it for you at a cost of $14.95.
Who pays for battery installation these days? With the parts stores doing it for free.
LS1Tech Administrator
Received 1,543 Likes
I always just go with the AC Delco Professional (their better series) for these cars, the CCA rating has gone up and down a bit over the years, but it's always been plenty even for the coldest weather. I always get 5-7 years from one of these, then replace it. The one in my '98 is now at 6 years old and is just beginning to show signs of weakness....probably could get another year out of it, but will likely replace it this spring.
AC Delco was one of my first thoughts for a replacement, however the nearest place to obtain one is nearly 20 miles away. I wish they were closer, its not that far but if im dealing with a battery issue 20 miles can be PITA.
Save the manuals!
Going for the AC-Delco may not give you better "performance" but my experience has also been that the cases are a little nicer and seem to be more rugged/durable.
If you want to avoid the long drive for something like the AC-Delco, then you should just go with whatever is the least expensive. (Comparing the warranty period on the batteries to make sure you are apples-to-apples.) The longer warranty batteries should have more pure internals and should last longer. (CCA's etc. should all be in the same ballpark unless you are looking at a deep-cycle battery. Those will have a lower CCA, but will perform better for you if the car sits long periods of time without being started.)
Yea I realize that most batteries are made by only a few companies and re-branded.
I was thinking about another Optima yellow top, as I have one in my off road toy CJ7, and it starts everytime no matter how long it seems to sit. But wasn't wanting to drop the coin on an optima, especially since the Hawk sits in the garage and can easily be hooked up to a $30 battery tender.
Save the manuals!
If you want to know what is reliable, you'd probably get better answers by asking people for their bad experiences and then use the process of elimination.
I didn't know that.
So, what are you trying to find out? If you just ask people what is best or what they are running, then they are going to tell you that what is in their car is the way to go. (If someone has spent their hard earned money on something, it must be the "best.")
Save the manuals!
I've found that batteries of similar construction and quality have the same/equivalent CCA ratings. So, (IMO) I don't think there is a lot of value in hunting for max CCA once one has settled on a battery type. I've always been suspicious of the number itself. Kind of like NFL player weights. The roster says 305, but they are really truly only 270 lbs.
I've got a Battery Tender 800 coming on Friday.
Plan to hook it up this weekend, and leave it on that when it sits for weeks. So if the interstate gives me trouble even after having it on the charger, then it will be confirmed as junk.
I hope this battery gets me till 2020, but time will tell.
As mentioned above, many of the brands are made by the same manufacturers and just packaged/labeled for different retailers. I don't like the ridiculous green/white case color of the Interstate branded units (do they sell one in black?) so I've never bought one, but I think what really matters is what wssix99 mentioned above - the warranty period. Those batteries that are offered with the most premium warranty should also have the most pure materials and thus longest lifespan. AC Delco offers two different warranty grades, with their "professional" series being the better of the two. I'm sure this is comparable to other brands with the same premium warranty.
My '98 is a seldom driven car, usually sitting for 2-3 weeks between drive periods during the on-season and for 4-6 months during the winter. I've never left a tender hooked up full time, but when it sits for 4 weeks or more I do hook up a smart charger until it's complete. Again, I'm up to 6 years on this same battery and it's just now starting to show early signs of lower-than-perfect voltage after sitting for a couple weeks.
I know some people really believe in having a tender hooked up full time for the weekend drivers, but I don't see how I could have gotten much better life out of this battery by doing things any different. 6-7 years of reliable service is about the best you can hope for no matter what maintenance practice you follow IMO.
Yes the top of the line Interstate battery comes in Black the Mega-Tron plus, with a 6 year warranty, 3 full 3 prorated I believe. I got the Mega-Tron II, which has a 5 year 3 full 2 prorated, and yes its in the ugly green white combo. Wanted the Plus, but it was out of stock, and just wanted this finished up so got the ugly one, might spring for a battery cover.
I've never used the tender before, but in the winter the Hawk will sit for a couple weeks waiting for good driving weather, so will use the tender then, in the summer hope to get more use/playtime with it, so probably won't use the tender much then.
