headlights flip up and down when keyless entry is used
Ok Well I Have A 2000 Ws6 And Whenever I Unlock Or Lock My Car With The Keyless Entry The Headlights Flip Up And Down And My Headlights Make A Grinding Noise For About 10 Seconds. So My First Question Is That Is The Keyless Entry Supposed To Flip Headlights Up And Down When I Lock And Unlock And My Second Question And More Importantly Is How Do I Fix My Headlights? Do I Nead New Gears Or A New Motor Or What?
Originally Posted by Mustang5.Ohater
One of the gears is stripped do the 180 temp fix and order the brass gears.
Ok time for Trans Am headlights one-on-one.........
(1)The headlights on our cars measures amperage (resistence) to know when the headlight is fully up and fully down. When a plastic
gear in the headlight motor gets stripped the system keeps powering the motors and thats why you hear a jackhammer noise when you lock/unlock the doors or when you turn on/off the headlights.
(2)The 180 temp fix is when you rotate the gear in the motor to the unused portion. The gear in the motor only uses half of a side to raise/lower the lights, so you have another half of the gear that has never been used.
Heres a step by step write up for the temp fix http://www.bfranker.badz28.com/headlightfix/index.htm#FreeGuide on that same page you can order some brass gears
to replace the plastic stock ones
. Hope this helps.
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
Copy & Paste Moderator
This is a sticky at the top of this section:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Here is another thread on the subject:
https://ls1tech.com/forums/showthrea...eadlight+noise
I had this just happen two weeks ago. Had an extra headlight hanging around from my last T/A and swapped it out. Fixed the problem. Weird how it seems to affect so many things!
