Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 02-21-2010, 11:48 AM
  #701
Danny2tek's Avatar
Originally Posted by YellowTA1
uuggghhhh, my '02 WS6 just started making that awful racket when i push the lock button, or when I turn on even just the park lights, the headlights pop up, but don't come on until i turn them on. also, they make the noise when i turn the lights off.... sound like the plastic gear problem? does anyone know if the guy still sells the upgraded gears to replace the crappy stock ones, if that is, in fact my problem??
Yes to both questions
Old 02-21-2010, 03:13 PM
  #702
t . b o z's Avatar
Originally Posted by t . b o z
Is there any way to adjust the motor itself? I think my headlights are closing too hard...I've been having my bulbs blow out very frequently. I think the jarring of the bulb while still hot is causing the filament to break prematurely. Anyone have information on this matter?
can anyone help me out?
Old 02-22-2010, 04:05 PM
  #703
Danny2tek's Avatar
Have you checked the stoppers to make sure they're ok?
Old 02-23-2010, 12:53 AM
  #704
t . b o z's Avatar
where are those?
Old 02-23-2010, 08:15 AM
  #705
WhiteLS1Formula's Avatar
Default headlight gear, where?
I have a 99 formula and its making the grind noise when i close the lights. Where can I get the aluminum gear? I would rather stay away from the plastic...Also, what price bracket are we looking at?
Old 02-23-2010, 08:57 AM
  #706
zdc590's Avatar
http://www.bfranker.badz28.com/headlightfix/index.htm I believe thats what youre referring to
Old 02-23-2010, 08:19 PM
  #707
ERL_'s Avatar
Where can I buy headlight parts? I'm missing that black cover around the lights on my driver side lights.
Old 02-24-2010, 05:50 PM
  #708
Jersey Mike's Avatar
My headlight motor just took a crap & I need to drive the car...
1) Which direction do you turn the Driver's Side gear to manually raise it? Clockwise or Counter-Clockwise
2) I've tried raising it manually, but it's not budging. Manually raising the passenger side is cake, but the driver's side won't give. ...?
Old 02-27-2010, 10:10 PM
  #709
Leedogg's Avatar
I have a set of brents gears...very nice product.
Old 03-03-2010, 12:09 AM
  #710
ERL_'s Avatar
im missing the black cover that goes around the lights on my driver side. im tryna buy some online. do i buy the right side, or left side. please help.
Old 03-04-2010, 07:03 PM
  #711
YellowTA1's Avatar
ok, so i got my new metal gear, got everything taken apart, except I can't find where to unplug the motor so I can take it out to install the new gear..it looks like it runs up behind some metal black thing....any hints??
Old 03-04-2010, 08:38 PM
  #712
Danny2tek's Avatar
Grab the connector itself (not the wires) that is behind the "black thing" and pull it out, its clipped on.
Old 03-05-2010, 08:22 AM
  #713
YellowTA1's Avatar
thanks danny, found it, pulled it out, got the gear switched out, let it sit all night, put it back together this morning, and problem solved...no more stupid embarassing noise....
Old 03-05-2010, 08:40 AM
  #714
Danny2tek's Avatar
Old 03-24-2010, 04:42 PM
  #715
venom 13's Avatar
My passanger side headlight will not go up at all. I do not hear anything like a motor trying to even activate. Is there an easy way to fix this? Replacment harness or something of the sort?
Thanks,
Matt
Old 03-24-2010, 06:49 PM
  #716
Danny2tek's Avatar
First make sure you voltage going into the harness for that headlight and you also have voltage leaving the harness going into the motor. If you do time for a new motor. Also make sure that the linkage isn't binding some how.
Old 03-24-2010, 07:51 PM
  #717
venom 13's Avatar
The headlight itself is on...should I just use a volt meter somewhere? If so, what wires/connections should I test? (I don't know which wires are the relay for the headlight motor.)
Thanks,
Matt
Old 03-24-2010, 08:00 PM
  #718
Danny2tek's Avatar
Thanks,
Matt
The harness is a 4 wire harness (underneath the headlight) IIRC, 2 wires for the actual "light" and the other wires are to power the motor. Just trace the wires that go to the the motor and see if you have power(volt meter) when you cycle the lights on/off
Old 03-24-2010, 08:10 PM
  #719
venom 13's Avatar
OK Thank you...I'll go try that. I remember trying to trace wires earlier, but I couldn't get underneath the lampp because it was stuck in the "down" position. Will I still be able to reach the spot to test?
Old 03-24-2010, 08:31 PM
  #720
Danny2tek's Avatar
you can "manually" raise the headlight by turning the top of the motor, you may have to remove a rubber boot.
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
