2001 Trans Am Bored
Old Aug 10, 2016 | 10:36 AM
94LS1B4C's Avatar
Default 2001 Trans Am Bored
Guy's im bored with my car. LS1/M6. Mods done are: Koni shocks, Strano springs, UMI trans crossmember, UMI subframe connectors, Stage II rpm transmission, Monster Clutch, Tick Slave, BTR Stage II Turbo Cam, TSP headers 1 7/8" w/ 3" ypipe, 80lbs injectors, Holley Fuel Rails, on E85, 317 Heads w/ BTR .660 springs. Everything else is stock. Obviously it shows I built the car for boost but don't have $4,000 to finish. Car is boring to drive and has aweful suspension/body noises. NO FUN
Old Aug 10, 2016 | 12:17 PM
Jeremy@RPMTransmissions's Avatar
Change the cam and sell the heads Get some 243s and give it a bunch of compression since its already on E85 and have some fun again. Spray it if you have to.
Old Aug 10, 2016 | 12:32 PM
94LS1B4C's Avatar
Jeremy I was hoping you would chime in! I will work on the 243's. What cam do you suggest?
Old Aug 10, 2016 | 12:33 PM
HCI2000SS's Avatar
I agree, either make it a strong n/a car, or keep saving for a turbo or blower. Not much else in between
Old Aug 10, 2016 | 12:37 PM
Just depends on how many RPM youre going to turn the engine and what intake manifold. I made 530rwhp with a 12.5:1 6.0 with an LS6 intake. So you can make good power without having to go to a FAST, MSD or single plane.
Id recommend a can in the mid 230s on the intake and mid to upper 240s on exhaust around .600 lift with a 113 LSA.
Old Aug 10, 2016 | 12:41 PM
94LS1B4C's Avatar
Well I wouldn't have much money in making it a NA car. The price of selling the cam and buying a new one, same with injectors, should be about the same. I could save the springs off of the 317's for the 243's.
I would love to make it a turbo car. I see about atleast another $3,500 to finish which would take me awhile to save seeing as I just bought a house. Plus that would be a bunch of good parts/turbo ontop of a stock bottom end aswell with 100k. It's not making much sense to me to turbo the car right now until have enough cash to build a motor for it.
Old Aug 10, 2016 | 12:43 PM
94LS1B4C's Avatar
Jeremy, it has the factory LS6 intake still. I'm not sure I could get close to the 12.5 CR. I don't want to tear into the engine. Maybe more like 11:1. Would it even be worth stay E85 at that point?
Old Aug 10, 2016 | 01:28 PM
You can get the dynamic compression up with valve events. I'm not sharp enough on cams to spec out your EVO/EVC/IVO/IVC ect. Get with someone who can spec you out a custom cam with modified valve events to get you as much dynamic compression as possible while making good power.
