which clock spring?
which clock spring?
hello all! im going a GM "corperate" steering wheel install in my 2000 SS camaro. i got a steel on my parts. corvette column for 45.00, steering wheel out of a saturn aura for 30 bucks. the wheel has paddle shifters. anyways im planning on using the paddles and running a TCI ez TCU. what clock spring are you guys running? the vette one was all mangled and wouldnt fit in the column to begin with. any help would be awesome!!
I saw your thread on FB but sorry I don't know what what clockspring you need... Have you taken the wheel apart to see if the buttons for the paddles are separate buttons with wires of if they're soldered to a board? If they're soldered to a board they would be communicating with the PCM/TCM via CANBUS. If you have any questions about setting up the TCI EZ TCU let me know, I'm running it with the TCI paddle shifters.
Its ok, It was easy to setup and easy to use, I just don't like how limited the settings are and I don't like the TCC lockup settings available, I'll be turning TCC off and only controlling it manually with a switch.
Thats good to know.
Do you have plans for your speedo? I had to run a DD signal converter to get my PCM VSS info as the TCU uses up the VSS sensor and it cannot be shared.
Thats good to know.
Thats good to know.
https://ls1tech.com/forums/pcm-diagn...questions.html
https://ls1tech.com/forums/stereo-el...plication.html
https://ls1tech.com/forums/automatic...s1-f-body.html
