Power seat height adjustment issue
Yesterday I noticed that when I tried to lower the rear of the seat (height adjustment), it wouldn’t do anything. The seat would raise up though. When I got home, I lifted the seat all the way up. It is now stuck. The weird thing I noticed is that the front of the seat will not go up, and the rear won’t go down. But when you try the opposite directions on both, you can see the motors working. I pulled the seat out and am looking to see if anyone knows what I should look for next.
Save the manuals!
You can put 12V to the motor and make sure it works. If so, then you likely have a switch problem. Here's a recent thread with another member about to take theirs apart for a rebuild: https://ls1tech.com/forums/general-m...l#post19884527
Well it was the switch. I took it to work, opened it up and found the rockers to have some corrosion on them. I cleaned them up and put it back together. Put the seat back together and plugged it in and wa la. The only issue left is the front height adjustment. That one doesn’t concern me as much as it is stuck at its lowest height, but would love to figure it out.
