Type of Plastic / Composition of 1997 Door Panels
It's sad. I worked for "the search engine" when they were brand new. It worked great back then, because the results were not "gamed".
Now, it's a piece of junk and it only pukes out what the billionaires want you to see.
I cannot use any set of search terms to find very specifically and without conjecture, what type of plastic is the door panel on a 1997 Trans-Am made out of?
All the conjecture: 97 was the year they changed or last year before they changed plastic type. (Ok? And? What is it?) 97's don't crack (they do). Etc.
I would just like the plastic code from a door panel. Mine is covered with glue. Is everyone else's?
If I knew WHERE under the glue it was, I'd clean that part, but I'm not stripping the whole mat out.
I tried searching on here, but there is nothing distinguishing about those search terms that don't bring up hundreds of unrelated topics.
Thanks!
Thanks!
Save the manuals!
The material is Sheet Molding Composite (SMC) https://gm-efi.com/features/gm-efis-...-chevy-camaro/
SMC is a specific material and has it's own repair products and procedures.
Awesome thanks! GM's choice of plastics is the gift that keeps on giving.
And that's for sure in 1997?
Do you know if that is the "new material" or the "old material"?
Since it cannot be rewelded, has anyone tried polyvance PP/GF rods on it? It's supposed to be "adhesive" and not melty.
And since it's plastic, I presume you can set "plastic staples" into it to stop progression?
Ok, based on the SMC info, I "took apart" the broken tab, and looked at it under my microscope.
I do not see any glass fibers in it.
Do I have the "other plastic" from the split year?
Alrighty, replying to myself so Google might pick this up for anyone else that needs the info.
Mine is a 04/97, April 1997
I ripped off the matting on the panel and used a very bright flashlight to shadow highlight the plastic stamps.
I found an SAE [PP] stamp
Since I cannot see any fibers in the piece of plastic that I sampled, I cannot verify that it is SMC, the [PP] leads me to believe I have the Polypropylene door panels.
Can anyone else confirm with an early 97?
LS1Tech Administrator
Received 1,509 Likes
SMC is the exterior (actual door) construction material, but not what is used for the interior (trim) panel.
I thought the interior plastics were ordinary abs plastic. The door panels crack because the combination of thinner material, temperature swings, and the placement of the staples makes them prone to cracking.
A electric plastic welder can be used to pull the crack closed.
Methyl Ethyl Ketone can melt it back together but the stuff is nasty.
Guess I should just look for a good one at a yard.
Save the manuals!
Thanks, yes. SMC is for the actual door. The decorative panel is not ABS. (Otherwise, it would be easy to repair the cracks it gets.) If I recall correctly, its Polypropylene. (I'm not sure.)
If you look on the back of the panel, there will be a stamp with some letters identifying the type of exact plastic : https://en.wikipedia.org/wiki/Resin_identification_code
When the door panel crack issue came up, we found there was no proper way to weld this particular type of plastic. There are only exotic glues that don't bond as strong as the original material.
You mention weld, then glue and bond. Not sure which definition you meant of weld, as in plastic welding, or weld (like with glue) to join a seam.
I used both an air welder with PP rod and then an airless and FiberFlex'd over it, with a steel mesh sammich between.
Welded fine, crack abated. 100% stronger than original now. Just have to monitor your heat.
Cosmetic side you have to know some advanced plastic repair, but that's doable also.
Polyvance is your friend. Ask for Scott in Product Development.
Repairing my cracked bumper cover in a few days. Just waiting on a body shop panel stand, those door panels killed my back bending over them.
Save the manuals!
Right. If you look at the reason for my original question, mine was covered with glue and I wondered if anyone had theirs exposed. After getting mixed replies, I did what I was avoiding and cleaned off the glue and found a SAE [PP]. Couldn't risk misinfo since mine was a split year.
I expect that you didn't have too much trouble getting the glue off the poly since things don't stick to it well.
