Will 4th Gen. seats fit in a 3rd Gen?
yes. teh rear seats aren't as wide, so they aren't as "good" looking in there. Also, the rear foldown was narrower too and the ancor bolt couldn't get locked on. THe center consoles have been swapped before (it must be a cup holder thing) but I'm not sure if people were using auto to auto & manual to manual direct swaps.
All the seats bolt in perfect, don't know where you got the info about it not sitting right?
All the consoles from the Firebirds will bolt right into a 3rd gen Firebird from 84 or 85 up, when they switched to the sleeker style. 3rd Gen camaros and 82-83 Firebirds are harder since thier HVAC and Radio are built into the console.
I've had a 4 sets of 4th gen seats in my cars over the years as well as the 97+ consoles with the nifty swing out cup holder,
my old 86 Trans Am
My 88 Formula,
And the Formula when it was an Auto with the B&M Megashifter,
my old 86 Trans Am
My 88 Formula,
Thanks for the info and thanks for the pix Zepher...
Yeah I am tired of my dads 3rd Gen sitting under a carport in our backyard...so I proposed he give it to me so I could get it looking/running good. There were no objections
We are the 2nd owner of the vehicle...the original was my uncle/cousin and the interior was abused quite well. It will be needing new carpet, seats, back passenger sail panels...All power works just fine!
Exterior: Body is in GREAT shape...no rust, dings or cracks on plastic bumpers. It has never been in a wreck! It is white, so I will most likely have it repainted that color to keep it looking original. I will also be replacing the tail lights...
Mechanical: It will be needing a new gears in the rear...most likely will redo the exhaust, has true duals out back but the mufflers are nasty soundn' now...It still has the crappy cross fire injection that floods like no other...is there a good replacement intake out there or will I be forced to carb it???
Originally Posted by Nate Dog 11
the info about the rear seats not fitting as good as the third gens are from the fact that I have 4th gen seats in the back of my car.
Are you talking about the seat bottoms?
About the fuel setup, carb would be the easiest, but you can do TPI if you'd like, just need to gather up a TPI Setup and install that and do some wiring and a fuel pump upgrade.
I did a carb to TPI setup on my old 86 Trans Am,
Or you can go all out and put an LT1/T56 setup in there,
Originally Posted by Midnite_LS1
Zepher - Do you have a hook up for a TPI conversion? Lemme know...I will be interested sometime by mid next month...
I'll take some pics of the TA later...
