Oem Radio Code Help
Old Apr 22, 2005 | 10:42 AM
compuvision02's Avatar
Default Oem Radio Code Help
E33
This shows when I try to load my CD changer. Anyways, I think it is E33, my display screen died, so I can sometimes see the numbers and stuff in the right light. I just replaced the CD changer with a new OEM one, because my old one jammed.
Old Apr 22, 2005 | 06:24 PM
ACW's Avatar
ACW
https://ls1tech.com/forums/showthrea...&highlight=e33
E33 : CD Changer Communication Error Cause(s): There is a vehicle/radio communication problem or internal radio communication problem. Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, determine if the problem is with the radio, the harness or the changer. Inspect for correct voltage at all connectors. If there is still an error, service the unit at an ACDelco® Service Center.
Old Apr 23, 2005 | 12:23 AM
Thanks ACW and damn you AC Delco, haha. How do I disconnect voltage to the radio?
Old Apr 23, 2005 | 12:34 AM
ACW's Avatar
ACW
You could interrupt the power at a number of places, probably the simplest would be to pull the Radio fuse in the fuse box
Fuse box diagrams: https://ls1tech.com/forums/showpost....89&postcount=2
Old Apr 23, 2005 | 11:00 AM
Thanks man!
