Ws9?
Old 01-03-2006, 08:47 PM
stangereater's Avatar
Default Ws9?
I own a 2000 WS6 in the RPO codes it has WS6 as well as WS9 i know what WS6 is so i decided to look up WS9 it said Formula converson my car is a TransAm though can some one explain what this means.
Old 01-03-2006, 08:55 PM
bbfirebird's Avatar
Every V8 Firebird is a Formula. Trans Am is only a trim option level which comes with a spoiler, ground effects, and TA badging. It also comes standard with options that would otherwise be optional on a standard Formula- for example, power windows, power door locks, power seats, etc. all come standard on a TA.
Old 01-03-2006, 08:59 PM
My friends 98 TA does not have this RPO though!
Old 01-03-2006, 11:02 PM
Danny2tek's Avatar
yep the evolution from v6 to v8 is WS9. From there it turns to WS6...etc.,etc...
Old 01-03-2006, 11:18 PM
bbfirebird's Avatar
W66 is another Formula option code. If it doesn't have WS9, it should have W66. If it doesn't, then it also shouldn't have RPO code LS1, because every V8 Firebird has the Formula option code.
Old 01-04-2006, 07:07 AM
Ateyate's Avatar
I learn something here every day Now, where would i find a list of RPO codes? Thanks!
Old 01-06-2006, 07:13 AM
Ateyate's Avatar
I found a list of RPO codes at the library in the GM factory service manual.
Old 01-13-2006, 04:01 PM
Kadonny's Avatar
www.firehawk.org
They list the RPO codes for our cars on that site. Check it out.
Old 01-21-2006, 10:50 PM
WS6TADRIVER's Avatar
The dealership can give you a printout of the RPO codes specifically for your vehicle by vin number and it tells on that sheet what they are... Got mine along with the window sticker all at the same time
Quick Reply: Ws9?
