Brass headlight gear issues :(
For those who replaced there headlight gears with brass
Hey guys,
I just got done replacing my gears in my headlight motors. They are curing as we speak I had to tap down the metal tabs on BOTH motors...grrrr
My only concern is each motor has a different amount of play in the gear. I cracked the one open that seemed tight just to make sure I didn't epoxy the gear , and I didn't. Does anyone think this will cause a problem? It still moves a little front to back. Any thoughts?'
Thanks
Bob s.
Thanks
Bob s.
Funny that you have a Maple Red Metallic TA just like one of my good buddies that installed the brass gears. His is a 2000 6 speed. He needed them and so did another buddy with a '98 NBM TA and I went ahead and got a set but have never had to install them yet. Anyway, he did have a little trouble later because of play and it did damage the brass gear. We got another gear and he figured out a way to take care of the play with a little insert he made and he did the same to both his light motors and the motors on the '98 as well and they have been fine since - about a year or so now. I know he figured out a way to use some small bolts to hold the cover really tight as well since one of the covers eventually popped off of the '98. Good luck!
Hey guys. I am in the middle of replacing my headlight gears with the brass ones fron Brent. I hooked them both the moters up. The passenger side spins fine. I have that just free spinning and not attached to the arm. Runs fine and smooth. The drivers side I have attached to the arm and bolted in, and I am having issues. The headlights turn on. I can manually raise and lower the headlight. BUT I it will not lower/raise under its own power. All I get is the headlights turn on and when you turn the lights off I get a faint click.
Since it can be raised and lowered manually I assume that the gears placement is fine and there is no excess epoxy on the gear gluing it up. Unfortunately that leaves me to believe the motor is bad. Before the gear install that motor did work.
Any idea what might have happned?
Thanks in advance.
Bob S.
Thanks in advance.
Bob S.
Do youi know which wires they are? And I guess what? Just take ohm meter? or continuity light? and probe the back? I don't pretend to know anything about electricity so any help would be awesome.
Bob S.
Bob S.
Take the gear out and then see if the motor will spin.
Also take a look at this from bfrankers site:
http://www.bfranker.badz28.com/headlightfix/tabs2.JPG
http://www.bfranker.badz28.com/headlightfix/tabs1.JPG
http://www.bfranker.badz28.com/headlightfix/tabs3.JPG
Make sure these tabs are pushed down! And make sure there is as little wobble as possible between the motor and the plastic housing.
ok now I found it it is somewhere in the connector. I wiggle it and it came on or went off. What did you use to clean the connectors? I see a little corrosion but my headlights come on and those terminals look the same. Also if one of the wires to the motor are loose? How do I go about tightening them? I didn't want to totally tear apart the connector.
Thanks for any help.
Bob s.
Bob s.
Originally Posted by brynnda
i heard the weight of the brass gear will ruin your motor for good?? anyone else?
Thanks in advance.
Bob S.
Thanks in advance.
Bob S.
http://www.bfranker.badz28.com/headl...htgearfailures
Also read there about #4 having to do with a bad connector.
One way to tell if it is getting jammed or not is to put the light in a mid position using the raise/lower **** and then electrically turn on the lights. If the light goes the rest of the way up you likely have a jamming issue (also, make sure you put everything back together correctly... the trim piece being out of place a little can cause the light to get jammed in position) but if it doesn't move you have either a connector problem, control problem, or the motor is bad. It is highly unlikely that the motor is bad... I've only heard of a couple cases where the motor itself went bad.
Give those a shot!
Bob S.
Bob S.
Originally Posted by Charlie Hustle
whatever you find out please let me know. mine are both stuck in the up position. they will raise by themselves, but i have to lower them manualy. before i spend the money on 2 new motors please let me know if anyone has any ideas.
give that a shot first. Cheap and easy
i heard it last year, i have probs with my motors now, i cant arm my car w/o them flopping up and down a couple times and making that god aweful niose (already been rotated) only reason i havent bought the brass gears, and i swore i heard it off this site.
brent - i know you
brent - i know you
