oil change light
oil change light
Does anybody know how to reset the oil change light. It stays on for about 5 minutes every time I turn the car on and then it turns off. I already changed the oil. What oil do you all recommend: regular or synthetic and what brand. 01 ws6 108,000 mi. Thanks
'Bird Director
There are two ways to do it:
#1) Turn the key to the "on"/"accessory" position (vehicle isn't running). Now push the gas pedal to the floor three times, and at least five seconds apart. The light won't come back on the next time the car is started.
#2) With the key in the "on"/"accessory" position (vehicle isn't running), push the trip odometer in and hold it for a few seconds. The light should go out and won't come back on the next time the car is started.
I could not be 100% correct on #2, but I use the #1 method and it works perfectly.
Copy & Paste Moderator
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by peterlawl84
Go With #2, Thats How It Is Stated In The Manual. Once The Light Is Reset, The Oil Change Light Will Flash Then Go Off.
I use #1
#2 ...........
As far as oil goes, Mobil,Castrol,Royal Purple are all good synthetics, but the best in the world is AMSOIL 5w-40 European Formula. It has a 25,000 mile life and blows all the others out of the water on abuse tests and oil anaysis. Hard as hell to find though. I'm going to be a vendor for it in the next month or so.
#2 ...........
Amsoil is popular too and many claim to be the best. German Castrol and Royal Purple aren't bad either.
