Power Steering Vibration
What does it mean if you feel a vibration in the power steering? It's not a whine, but more of a grumble, and a vibration is felt on the steering wheel. The fluid is at the right level.
Could it be air trapped in the rack & pinion?
I appreciate any ideas.
What was fun about it is I changed the fluid...did nothing...changed the PS pump...did nothing. In the mean time I talked to TurnOne and the tech there (who was VERY FREINDLY AND HELPFUL through the whole ordeal..and it wasnt even their pump!) said it sounds like it has to be an obstruction in the high pressure side. I told him I had changed pumps and that didnt do it...so the next step was to check the line. So I took it off and it appeared to be normal and free flowing...so I put it back on. Finaly I checked the ports that the lines connect to on the rack and they were fine. He said the only other thing he knows to do is send them the rack to test or get a rebuilt one. So I just ordered a rebuilt one and while I was waiting on it to come in I said what the hell and replaced the high pressure line...and like magic it fixed it! Then I realized when I checked it it was cold and the problem on started after it got hot....DUH!
Anyway...just dont forget your lines can fail too!
Thank you very much for the detailed clarification.
Did you feel this vibration turning both ways, or just one direction?
My high pressure hose is actually new. It was installed a few months ago, and I only experienced this vibration only recently. The last thing that was done to the power steering was re-assembling the o-rings onto the connection points of the reservior. For some reason, I only feel the vibration when I turn left.
Could trapped air give this effect also?
