93 30,800 miles If I custom paint it will it lose value????
I have a 93 that has super low miles. If I paint it with custom color will it lose value???? Should I just paint it with OEM PPG paint???
I don't know if it would... but I probably would not change the original paint. Painting all the other stuff.... door jambs,ect is a PIA and it will co$t you more, espically if you are having the car painted by someone else.
Yeah, you are hurting the 'collector' value. If it must have paint then it should be kept the original color. If you are going to be driving it a lot in the future then the higher mileage will negate any paint change since the car will be worth less as you pile on the miles. What were your plans?
93 trans am
It is a v-8 trans am. I will leave it oem then. When i open the car door the car still smells brand new. I am putting a firehawk hood on it just for looks with some fikse's. I will post pics when I am done. I don't want to change the color just add some ghost flames or maybe a ghost comp t/a look on it. Something subtle.
