Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
Magna Flow Exhaust INSTALLED, My thoughts
Old 11-25-2008, 03:37 PM
blownerator
BlownChevy's Avatar
Originally Posted by Heavy H.P.
So that exhaust has no drone at all?
Yes, you can hear it on the inside of the car...The severity is truly up to the discretion of the user. I have had some loud exhaust in my life and this is quite nice both inside and out.
Originally Posted by skywalkrNCSU
just curious is it much louder than the stock setup during typical driving? I am sure it is when you get on it
3 db on the interior, and noticeable on the outside.
Old 11-25-2008, 06:37 PM
99SSragtop's Avatar
Originally Posted by BlownChevy
Must be the angle of the picture. When looking at the car from behind they are dead even. I will double check tomorrow.
Nice post count.
Old 11-25-2008, 07:49 PM
Jimmyz's Avatar
Is the 09 any different whatsoever? I've heard Blue tooth and gauges and that's it.
Old 11-26-2008, 03:54 PM
Cashed's Avatar
So far an 09 with Bluetooth has yet to even be released. GM is now saying BT will be on 09 1/2 models. They did remove the "Atari" gauges from the center of the dash. Replaced them with a cubby hole. You can get XM on 09s. Other than that, 08s and 09s are the same.
Old 11-26-2008, 05:21 PM
ULTIMATEORANGESS's Avatar
magnaflow makes quality systems. that looks real nice.
Old 11-26-2008, 11:51 PM
blownerator
BlownChevy's Avatar
Clipped from another board I posted on:
In my opinion: If you are going to buy an exhaust system based on what you hear in low res on the internet you are making a mistake. I think you are better off waiting until someone in your area has the exhaust system and you can hear it in person.
If you are on the fence, a sound clip on the web is not going to make a world of difference. I can say this, I am critical....no, over critical of interior and exterior noise. This system is NOT over bearing or annoying inside or out.
Again, that is my "opinion" others may have different criteria they base their "opinions" on. Key word "subjective".
To answer your question: It is not much louder in my opinion....However I feel that is subjective.
Quick Reply: Magna Flow Exhaust INSTALLED, My thoughts
