No traction
#41
well we just got the tranny back on my trans am so i'm going to run that this friday. so either this wednesday or next wednesday i'm going to borrow some stock camaro 17s with drag radials and go try it again.
#42
I'm not sure if those will fit. Keep in mind backspacing. I know that you could probably fit a GTO 17 inch rim with no problems. I plan on doing that, and using my 275/45/17 MT ET street radials off the fun car for the track. I could be wrong, just don't want you to waste your time finding out the hard way... Better safe than sorry, you know?
#43
I have a set of the 17x9s and they will fit the G8.
You can also use Vette 18x9.5s (56? offset) if you want to use an 18" DR.
#44
I know it is a small difference, but in some cases that difference means it won't fit. The wheels have been off the car to rotate, and that's about it... so far...
#47
