Pontiac G8 WOW!!!
#41
Wow. I find that surprising. Considering it is the same V6 as the CTS. I'd think that a lot of people would be looking at modding them a little. Just the basics at least. Intake, exhaust, etc.
#44
And the main pulley wobble. There is some plastic spacer that apparently comes apart causing this, which has led to belts being shredded or thrown.
#47
You can see the runout in my harmonic balancer.... GM refused to replace multiple times. As well with the power steering pulley! It causes a squeak every morning for about 15 minutes.
GM refused to spend the 23 dollars to replace my powering steering pulley even though there was a service bulletin.
Now that I have over 36K miles they flat out refuse to even look at the car. Apparently, pullies and harmonic balancers aren't part of the 100K powertrain warranty.
