What kind of fuel economy are you guys getting with your G8s?
1 Post
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
You could be a lucky exception then. Most people I know report it's not completely accurate and the DIC in my Impala SS comes up anywhere from almost spot on to up to 2mpg too high.
The gears i think are 2.92's, talk about killing gas mileage and performance. Gears that low will lug the **** out of the engine and make gas mileage worse than good, what the hell is wrong with GM sometimes.
i feel like a broken record, but my audi rs6 (540hp twin turbo V8) >4200lbs, i would hover on 28mpg on a long mutli hour stretch of hwy.
As a data point I have had my G8 for 2 weeks and only driven 560 miles. On my 2nd tanks of gas (about 1/4 left) I am averaging 18.9 mpg for my drive which is about 2/3 city/back road (lots of stops and starts) and 1/3 hwy (about 6 mile shot each way).
Have you taken your G8 on the same long multi hour stretch of hwy? The RS6 is a 4.2L engine which should do better on a hwy cruise if you are not into the boost. Just so you know, by the new 2008 EPA fuel economy rating the G8 GT and a 2004 Audi RS6 have the same city rating at 15 MPG and the G8 is rated 2 mpg better than the RS6 at 24 mpg on hwy. As for the AFM (DOD) response on the hwy I am not sure what you are talking about, it jumps out of 4 cyl mode the instant you tap the gas. Have you watched it on engineer mode? If anything I think GM has it disengaging a little too soon. A few people have seen improved mileage when upping the AFM deactivation point from the 6% throttle positon it is set at to something like 11%.
#32
I picked my GT up in CT. on May 10th and have done nothing to it yet.
I just made a trip from North Carolina home to Connecticut.
I started the trip home with 2163 miles on it.
I filled up at Flying J in Fort Chiswell, VA with 87 octane.
I had already done 110 miles so the car was warmed up.
Running tire pressure was 39 front and 41 rear.
Ambient temperature during the drive was 70 - 74 degrees,
with low humidity and sunny skies.
A.C. was set to 72 degrees and on auto.
Put the car in drive and got onto I-81 N.
I pulled into the Flying J above Winchester, Va. 246.5 miles later.
DIC showed 68.1 avg. speed, 27.3 M.P.G. and 329 mile range remaining.
Tank took 8.792 gallons which calculates to 28.03 M.P.G.
I was very gentle on the throttle for this drive to see what I could
get for max mileage. Other than getting onto and off of the highway
I maintained my speed between 60 and 75 M.P.H.
Got back onto the highway and stopped 276.3 miles later at the
Valero station in Port Jervis, NY just off I-84 E.
DIC showed 67.8 avg. speed, 25.0 M.P.G. and 271 mile range remaining.
Tank took 10.802 gallons which calculates to 25.57 M.P.G.
This tank I drove normally, which means more throttle, but nothing crazy.
I am quite happy with the mileage I am getting.
Most of my driving is highway. My city driving is really mostly rural roads;
not real stop and go type city. The first couple of tanks of gas were a
variety of driving and I averaged between 19.5 and 22 so I am happy with
that also.
that also.
#34
Why would putting a higher gear ratio make the mileage improve??? You'd want a LOWER gear to get better gas mileage so the engine is turning lower RPM's. It cruises at about 1500 on the highway as it is in 6th gear.
